Ir para o conteúdo principal
Samsung Galaxy Note 10.1 2014 Screen Replacement
O que você precisa
  1. Samsung Galaxy Note 10.1 2014 Screen Replacement, Case: passo 1, imagem 1 %32 Samsung Galaxy Note 10.1 2014 Screen Replacement, Case: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Spudger
    $2.99
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
    Pergunte ao FixBot
  2. Samsung Galaxy Note 10.1 2014 Screen Replacement, Battery: passo 2, imagem 1 %32
    • Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
    • Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
    Pergunte ao FixBot
  3. Samsung Galaxy Note 10.1 2014 Screen Replacement: passo 3, imagem 1 %32
    Phillips #000 Screwdriver
    $5.49
    Pergunte ao FixBot
  4. Samsung Galaxy Note 10.1 2014 Screen Replacement: passo 4, imagem 1 %32 Samsung Galaxy Note 10.1 2014 Screen Replacement: passo 4, imagem 2 %32
    Spudger
    $2.99
    • Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
    • Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
    Pergunte ao FixBot
  5. Samsung Galaxy Note 10.1 2014 Screen Replacement, Loudspeaker Modules: passo 5, imagem 1 %32 Samsung Galaxy Note 10.1 2014 Screen Replacement, Loudspeaker Modules: passo 5, imagem 2 %32
    • Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
    • Remove the one 3mm screw on the top left side of the device with the same method.
    Pergunte ao FixBot
  6. Samsung Galaxy Note 10.1 2014 Screen Replacement, loudspeaker  - remove right speaker: passo 6, imagem 1 %32 Samsung Galaxy Note 10.1 2014 Screen Replacement, loudspeaker  - remove right speaker: passo 6, imagem 2 %32 Samsung Galaxy Note 10.1 2014 Screen Replacement, loudspeaker  - remove right speaker: passo 6, imagem 3 %32
    • Remove the gray rubber piece.
    • Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
    • Remove the right speaker unit.
    Pergunte ao FixBot
  7. Samsung Galaxy Note 10.1 2014 Screen Replacement: passo 7, imagem 1 %32 Samsung Galaxy Note 10.1 2014 Screen Replacement: passo 7, imagem 2 %32 Samsung Galaxy Note 10.1 2014 Screen Replacement: passo 7, imagem 3 %32
    • Remove the loudspeaker modules located on the parts where the screws were removed by using the black nylon spudger.
    • They are the black pieces at the top left and right corners of the device that have metal squares on them in the middle.
    Pergunte ao FixBot
  8. Samsung Galaxy Note 10.1 2014 Screen Replacement, Rear Camera: passo 8, imagem 1 %32 Samsung Galaxy Note 10.1 2014 Screen Replacement, Rear Camera: passo 8, imagem 2 %32
    • Disconnect the camera piece from the motherboard.
    • The camera piece is shaped like an "L".
    Pergunte ao FixBot
  9. Samsung Galaxy Note 10.1 2014 Screen Replacement, Motherboard: passo 9, imagem 1 %32 Samsung Galaxy Note 10.1 2014 Screen Replacement, Motherboard: passo 9, imagem 2 %32 Samsung Galaxy Note 10.1 2014 Screen Replacement, Motherboard: passo 9, imagem 3 %32
    • Disconnect all cables on the motherboard.
    • See our connector guide for help safely disconnecting various types of connectors.
    Pergunte ao FixBot
  10. Samsung Galaxy Note 10.1 2014 Screen Replacement: passo 10, imagem 1 %32 Samsung Galaxy Note 10.1 2014 Screen Replacement: passo 10, imagem 2 %32 Samsung Galaxy Note 10.1 2014 Screen Replacement: passo 10, imagem 3 %32
    • Use the black nylon spudger to gently lift the motherboard away from the frame.
    • Remove the motherboard.
    Pergunte ao FixBot
  11. Samsung Galaxy Note 10.1 2014 Screen Replacement, sreen - remove middle frame: passo 11, imagem 1 %32
    • remove middle frame by pulling it off
    Pergunte ao FixBot
    • follow as shown on TechGuru.gr
    • Screen burst, be aware of glass splinters. May you cover the screen with tissue
    Pergunte ao FixBot
  12. Samsung Galaxy Note 10.1 2014 Screen Replacement, screen - seperate buttons from screen: passo 13, imagem 1 %32
    • buttons are glued to frame, gently lift up screen
    • pull of cable, connecting the buttons, gently
    Pergunte ao FixBot
  13. Samsung Galaxy Note 10.1 2014 Screen Replacement, screen - clean: passo 14, imagem 1 %32
    • rub of the glue with the fingers
    • remove residues with makeup remover or similar
    Pergunte ao FixBot
Conclusão
9 outras pessoas executaram este guia.
Stefn Mueller
Membro desde: 12/23/15
403 Reputação
Autoria de 1 guia
4Comentários do guia
is the digitizer glued to the lcd screen?
Amiel D Hechanova - Responder Compartilhar
it is see referenced YouTube video
https://tinyurl.com/yccgecgh
Stefn Mueller - Responder Compartilhar
The e battery and screen cable clasps that hold tge cables in….. Where do i get them repaired
Paul Brook - Responder Compartilhar
Hi can somebody help me
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 127
Ao todo: 11,752
