Introdução
Is the quality of your photo not up to par?
This simple guide will help you replace the front camera lens for your Galaxy Nexus.
Ferramentas
Peças
You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
This is when a new battery will be inserted.
Use the tweezers flip up the circuit for the front camera.
Use the tweezers pull out the front camera.
4 outras pessoas concluíram este guia.
