Peças
Não são necessárias peças.
  1. So your Verizon Galaxy Nexus won't charge, charges sometimes, or thinks it's charging when it's not plugged in? It might be time to replace the micro USB connector board. For this repair you'll need:
    • So your Verizon Galaxy Nexus won't charge, charges sometimes, or thinks it's charging when it's not plugged in? It might be time to replace the micro USB connector board.
    • For this repair you'll need:
      • An opening tool.
      • Small Phillips screwdriver.
      • A replacement micro USB board. I found mine here.
    • The original board I removed was revision LF-A G 1145. The new one (pictured) was LF-A G 1150 23-3.
  2. Start by removing the battery and SIM card. Once the battery and SIM are out, remove all six screws from the back.
    • Start by removing the battery and SIM card.
    • Once the battery and SIM are out, remove all six screws from the back.
  3. The next step is to remove the back from the phone. Using the plastic opening tool gently pry around the edge of the screen. It should come off without too much fuss.
    • The next step is to remove the back from the phone.
    • Using the plastic opening tool gently pry around the edge of the screen. It should come off without too much fuss.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Next we need to remove the antenna, speaker, and vibrator assembly from the bottom. Start by removing the screw. Then use the opening tool to disconnect the ribbon cable.
    • Next we need to remove the antenna, speaker, and vibrator assembly from the bottom.
    • Start by removing the screw.
    • Then use the opening tool to disconnect the ribbon cable.
  6. The assembly is clipped to the magnesium body of the phone. It's not very easy to unclip, unless you have a Google GSM phone. CDMA: Rotate the assembly counter-clockwise. I ended up breaking the clip off because I tried prying.
    • The assembly is clipped to the magnesium body of the phone. It's not very easy to unclip, unless you have a Google GSM phone.
      • CDMA: Rotate the assembly counter-clockwise. I ended up breaking the clip off because I tried prying.
      • GSM: For my Google GSM phone, you just needed to push the clip away from the assembly.
    • The clip used to be here.
  7. Next we need to detach some ribbon cables and an antenna cable from the main circuit board. Micro USB board. Also has the front notification LED and the main microphone.
    • Next we need to detach some ribbon cables and an antenna cable from the main circuit board.
      • Micro USB board. Also has the front notification LED and the main microphone.
      • Screen connector.
      • Volume rocker. Some phones have this soldered to the mainboard - not CDMA.
        • GSM/Soldered: One user was able leave the volume rocker alone, and instead focus on the power button. You can gently separate the power button from the case - held in place only by glue - without remove detaching it from the circuit board. You can then rotate the circuit board out of your way.
      • Antenna.
    • Gently detach with the plastic opening tool.
  8. Gently remove the main circuit board. Keep in mind there are some ribbon cable connectors underneath the board. These should pop off easily, or you can use the opening tool to gently remove them once you have the board lifted up a bit. Also be mindful that these get reconnected with you put everything back together!
    • Gently remove the main circuit board.
    • Keep in mind there are some ribbon cable connectors underneath the board. These should pop off easily, or you can use the opening tool to gently remove them once you have the board lifted up a bit. Also be mindful that these get reconnected with you put everything back together!
      • Power button cable.
      • Earphone cable.
    • The main circuit board also is connected to the main camera and the front facing camera with more ribbon cables. These should stay attached, but be delicate. You don't want to get dust in them when you seal everything back up!
  9. Now we can finally replace the micro USB board. It has some light adhesive holding it on. Some work with they pry tool and your fingers should free it easily.
    • Now we can finally replace the micro USB board.
    • It has some light adhesive holding it on. Some work with they pry tool and your fingers should free it easily.
    • The board left behind some of its adhesive. Make sure to remove it.
  10. With the broken USB board gone we can install the new one! Peel off the adhesive backing and install the new board. There are a number of pins and guides that make accurate installation easy.
    • With the broken USB board gone we can install the new one!
    • Peel off the adhesive backing and install the new board.
      • There are a number of pins and guides that make accurate installation easy.
Conclusão
150 outras pessoas concluíram este guia.
Sam Thompson
2.629 reputação
Autoria de 1 guia
These guys figured out the GSM version:
http://www.japanmobiletech.com/2012/07/r...
I didn't need to break the orignal part as cannonfodder described.
Nic - Responder
Fantastic. I could use this and fix my Galaxy Nexus. What a relief!
Few suggestions though -
My Galaxy Nexus is of a GSM model - so the build inside is little different than what was depicted here for the CDMA one. I gathered some information from http://www.japanmobiletech.com/2012/07/r... on the GSM aspects. I also watched the Galaxy Nexus Disassembly and Asssembly video during the repair process - http://www.youtube.com/watch?v=B5fZzZANL....
It took me an hour roughly to successfully finish the job. Thank you Sam.
Chandra - Responder
GSM OWNERS
Read the comments before you proceed with this guide. There are some notable differences between CDMA and GSM, including:
* Volume and power buttons are probably soldered to the mainboard
* The vibrator is separate from the bottom speaker assembly and should be carefully removed using a spudger (but be careful not to tear the soldered wires
* The screws are located in different positions, all on top of the back plastic cover
** Step 4: I didn't have an additional screw below the plastic back
* Comments on Step 7 are great - to replace the USB ribbon, you must gently lift the bottom of the mainboard up, slide out the old USB ribbon, and slide the new one in. Don't take the mainboard completely out, or you'll break the soldered power and volume connections.
Good luck and happy fixing!
Jonathan Samonas - Responder
Was super easy for CDMA, I broke the clip in Step 5 but it still works!
caitlynoleykowski - Responder
Thanks for the great guide. I've dropped my phone a couple times with the USB cord plugged in and the port had gotten stretched a little bigger. I was able to get to the port and used a pair of needlenose pliers to make the port a little smaller. Now my USB cord stays in like its supposed to. Thanks so much!
lightmaster - Responder
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 65
Todo: 162,145
