Ir para o conteúdo principal
Samsung Galaxy Mega USB Board Replacement
O que você precisa
  1. Samsung Galaxy Mega USB Board Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Mega USB Board Replacement, Battery: passo 1, imagem 2 %32 Samsung Galaxy Mega USB Board Replacement, Battery: passo 1, imagem 3 %32
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega USB Board Replacement: passo 2, imagem 1 %32 Samsung Galaxy Mega USB Board Replacement: passo 2, imagem 2 %32 Samsung Galaxy Mega USB Board Replacement: passo 2, imagem 3 %32
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega USB Board Replacement, Midframe: passo 3, imagem 1 %32 Samsung Galaxy Mega USB Board Replacement, Midframe: passo 3, imagem 2 %32 Samsung Galaxy Mega USB Board Replacement, Midframe: passo 3, imagem 3 %32
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega USB Board Replacement: passo 4, imagem 1 %32 Samsung Galaxy Mega USB Board Replacement: passo 4, imagem 2 %32
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega USB Board Replacement, USB Board: passo 5, imagem 1 %32
    • This circuit board is the charging port assembly.
  6. Samsung Galaxy Mega USB Board Replacement: passo 6, imagem 1 %32 Samsung Galaxy Mega USB Board Replacement: passo 6, imagem 2 %32 Samsung Galaxy Mega USB Board Replacement: passo 6, imagem 3 %32
    • Lift up on the clamp with your finger to disconnect the connector.
    • Lift up on the clamp with your finger to disconnect the connection to the mother board.
    • Grasp cable head and lift up to disconnect the cable head.
  7. Samsung Galaxy Mega USB Board Replacement: passo 7, imagem 1 %32 Samsung Galaxy Mega USB Board Replacement: passo 7, imagem 2 %32
    • Use your fingers to gently remove charging port.
Conclusão
10 outras pessoas executaram este guia.
Aaron Fulton
Membro desde: 02/04/16
1.246 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 17-2, Blackwell Winter 2016 Membro de USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 8,682
