Ir para o conteúdo principal
Introdução
This guide instructs on how to replace the back panel audio speaker.
Peças
Nenhum componente especificado.
  1. Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: passo 1, imagem 2 %32 Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: passo 1, imagem 3 %32
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Speaker Assmebly Replacement: passo 2, imagem 1 %32 Samsung Galaxy Mega Speaker Assmebly Replacement: passo 2, imagem 2 %32 Samsung Galaxy Mega Speaker Assmebly Replacement: passo 2, imagem 3 %32
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: passo 3, imagem 1 %32 Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: passo 3, imagem 2 %32 Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: passo 3, imagem 3 %32
    • Remove the 6 3.45 mm Phillips #000 screws from the bottom of the assembly surrounding the speaker.
    • Gently insert plastic opening tool through the inside groove of the speaker assembly.
    • Once the top part of the speaker assembly pops free. Gently lift up with your fingers to remove speaker.
Conclusão
Uma outra pessoa concluiu este guia.
nithin
Membro desde: 04/02/2016
137 Reputação
Autoria de 1 guia
USF Tampa, Team 17-2, Blackwell Winter 2016 Membro de USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 Membros
8 Guias de autoria
0 Comments
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 783
