Ir para o conteúdo principal
Samsung Galaxy Mega 2 LCD/Digitizer Replacement
O que você precisa
  1. Samsung Galaxy Mega 2 LCD/Digitizer Replacement, LCD/Digitizer: passo 1, imagem 1 %32
    • Before beginning, make sure the phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 LCD/Digitizer Replacement: passo 2, imagem 1 %32 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: passo 2, imagem 2 %32
    • Locate the battery
    • Insert fingernail or plastic opening tool into the slot on the bottom of the battery and gently lift up.
    • Remove the battery
  3. Samsung Galaxy Mega 2 LCD/Digitizer Replacement: passo 3, imagem 1 %32 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: passo 3, imagem 2 %32 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: passo 3, imagem 3 %32
    • Use phillips head PH000 and remove all 13, 1.4 mm visible screws.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use the pry tool to disconnect the digitizer
  4. Samsung Galaxy Mega 2 LCD/Digitizer Replacement: passo 4, imagem 1 %32 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: passo 4, imagem 2 %32 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: passo 4, imagem 3 %32
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembly frame.
    • Be careful and do not lift the screen completely off yet, leave the screen at an angle.
    • Use the heat gun to heat up the bottom to loosen the adhesive from the menu and back buttons.
    • Once heated, gently pull the screen upward.
    • Make sure that the buttons are separating from the adhesive.
  5. Samsung Galaxy Mega 2 LCD/Digitizer Replacement: passo 5, imagem 1 %32 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: passo 5, imagem 2 %32 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: passo 5, imagem 3 %32
    • Flip the screen over.
    • Locate the LCD/Digitizer.
    • Then disconnect the LCD/Digitizer using tweezers.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 1,733
