Ir para o conteúdo principal
Samsung Galaxy Mega 2 Battery Replacement
O que você precisa
  1. Samsung Galaxy Mega 2 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Before begining, make sure the phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once you get the corner released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Battery Replacement: passo 2, imagem 1 %32 Samsung Galaxy Mega 2 Battery Replacement: passo 2, imagem 2 %32
    • Locate the battery.
    • Insert fingernail or plastic opening tool into the slot on bottom of the battery and gently lift up.
    • Remove the battery.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 1,289
