Ir para o conteúdo principal
Samsung Galaxy Luna Motherboard Replacement
O que você precisa
  1. Samsung Galaxy Luna Motherboard Replacement, SIM Card: passo 1, imagem 1 %32
    • Using a plastic opening tool, pry the divot to the left of the camera to take off the rear case.
  2. Samsung Galaxy Luna Motherboard Replacement: passo 2, imagem 1 %32
    • Pull the corner nearest to the divot to remove the case from the phone.
  3. Samsung Galaxy Luna Motherboard Replacement: passo 3, imagem 1 %32 Samsung Galaxy Luna Motherboard Replacement: passo 3, imagem 2 %32
    • Place your fingernail or a prying tool at the bottom of the battery and pry it out of the case.
  4. Samsung Galaxy Luna Motherboard Replacement: passo 4, imagem 1 %32 Samsung Galaxy Luna Motherboard Replacement: passo 4, imagem 2 %32
    • By using your finger or a plastic opening tool, push the SIM card further into its container until a click is heard.
    • Once the click is heard grab the SIM card and slide it out of the container.
    • Remove the SIM card completely.
    • During reassembly, slide the new SIM card into the slot until a click is heard.
  5. Samsung Galaxy Luna Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Samsung Galaxy Luna Motherboard Replacement, Motherboard: passo 5, imagem 2 %32 Samsung Galaxy Luna Motherboard Replacement, Motherboard: passo 5, imagem 3 %32
    • Use a plastic opening tool, or your fingernail to to take off the rear case by prying the divot to the left of the camera.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Using an opening tool, take off the cover for the digitizer connector.
    • detach the connector with a tweezer or a plastic spudger.
  6. Samsung Galaxy Luna Motherboard Replacement: passo 6, imagem 1 %32 Samsung Galaxy Luna Motherboard Replacement: passo 6, imagem 2 %32 Samsung Galaxy Luna Motherboard Replacement: passo 6, imagem 3 %32
    • Place small suction cup on the center of screen and press firmly.
    • Hold the back of the phone and pull on the suction cup gently until the screen begins to bend.
  7. Samsung Galaxy Luna Motherboard Replacement: passo 7, imagem 1 %32 Samsung Galaxy Luna Motherboard Replacement: passo 7, imagem 2 %32
    • Insert the small metal spudger into an opening on the phone and pry off the screen.
    • Avoid tearing any exposed circuits as the screen is being removed.
    • Make sure the screen is completely detached from the motherboard before removing it.
  8. Samsung Galaxy Luna Motherboard Replacement: passo 8, imagem 1 %32 Samsung Galaxy Luna Motherboard Replacement: passo 8, imagem 2 %32
    • Using a Philips PH000 screwdriver, remove the nine 3 mm screws.
  9. Samsung Galaxy Luna Motherboard Replacement: passo 9, imagem 1 %32 Samsung Galaxy Luna Motherboard Replacement: passo 9, imagem 2 %32
    • Using a metal spudger, gently pry the button frame off the motherboard.
    • Do the same for the motherboard.
    • Avoid scraping the circuitry on the motherboard, as they can be very fragile.
  10. Samsung Galaxy Luna Motherboard Replacement: passo 10, imagem 1 %32 Samsung Galaxy Luna Motherboard Replacement: passo 10, imagem 2 %32 Samsung Galaxy Luna Motherboard Replacement: passo 10, imagem 3 %32
    • Using a Philips PH000 screwdriver, remove the black screw.
    • Use the metal spudger to pry open the motherboard cover.
    • Be careful when prying the cover of the motherboard. avoid scratching the motherboard circuitry.
Conclusão
Equipe
USF Tampa, Team S6-G1, Eyestone Spring 2018 Membro de USF Tampa, Team S6-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S6G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 717
