Ir para o conteúdo principal
Samsung Galaxy Luna LCD display Replacement
O que você precisa
  1. Samsung Galaxy Luna LCD display Replacement, LCD display: passo 1, imagem 1 %32
    • Attach a small suction cup to the lower half of the glass screen.
  2. Samsung Galaxy Luna LCD display Replacement: passo 2, imagem 1 %32
    • Apply pressure to the middle section of the screen while pulling up the lower edge by pivoting your wrist.
  3. Samsung Galaxy Luna LCD display Replacement: passo 3, imagem 1 %32
    • Once you've opened a large enough gap, insert a Spudger tool between the glass and the motherboard.
    • Slide the Spudger tool around the gap until the screen is completely separated from the motherboard.
    • The LCD is very fragile,be careful when sliding the spudger around the gap.
  4. Samsung Galaxy Luna LCD display Replacement: passo 4, imagem 1 %32 Samsung Galaxy Luna LCD display Replacement: passo 4, imagem 2 %32
    • Pull the rear panel up and away to completely separate it.
    • make sure the panel is completely detached from the phone frame before separating it.
  5. Samsung Galaxy Luna LCD display Replacement: passo 5, imagem 1 %32 Samsung Galaxy Luna LCD display Replacement: passo 5, imagem 2 %32 Samsung Galaxy Luna LCD display Replacement: passo 5, imagem 3 %32
    • Place the spudger tool between the LCD and the glass screen.
    • Slide the spudger tool in between the screen and the display until both are completely separated from each other.
    • The LCD is very fragile, do not apply excessive force when prying the glass panel
Conclusão
xingyu chen
Membro desde: 02/14/18
266 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S6-G1, Eyestone Spring 2018 Membro de USF Tampa, Team S6-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S6G1
Membros da 4
Autoria de 5 guias
2 comentários
Hola, cual es el numero de parte de la pantalla a reemplazar?
Luis A. Andueza - Responder
It appears that OEM screens are no longer available for this phone. I was able to find this third party display assembly that looks like it would work, but I can’t attest to its functionality, so there would be a bit of risk involved for you. Hope that helps!
Austin Blakely -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,043
