Ir para o conteúdo principal
Samsung Galaxy Light Motherboard Replacement
O que você precisa
  1. Samsung Galaxy Light Motherboard Replacement, Remove Back Cover: passo 1, imagem 1 %32
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Motherboard Replacement, Remove Battery: passo 2, imagem 1 %32
    • Remove the battery from the device.
  3. Samsung Galaxy Light Motherboard Replacement, Unscrew Midframe: passo 3, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Motherboard Replacement, Remove Midframe: passo 4, imagem 1 %32
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: passo 5, imagem 1 %32 Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: passo 5, imagem 2 %32 Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: passo 5, imagem 3 %32
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
Conclusão
7 outras pessoas executaram este guia.
Diandra
Membro desde: 10/16/14
198 Reputação
2 Guias de autoria
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,079
