O que você precisa
Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
Pry open the cover: Carefully work around the edges to remove the back cover completely
Once your device's back has been disassembled, grab the panel that has the volume buttons.
Quase terminado!
Conclusão
