Ir para o conteúdo principal
Samsung Galaxy J7 Vibration Motor Replacement
O que você precisa
  1. Samsung Galaxy J7 Vibration Motor Replacement, Back Cover: passo 1, imagem 1 %32 Samsung Galaxy J7 Vibration Motor Replacement, Back Cover: passo 1, imagem 2 %32
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
  2. Samsung Galaxy J7 Vibration Motor Replacement, Midframe: passo 2, imagem 1 %32
    • Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
  3. Samsung Galaxy J7 Vibration Motor Replacement: passo 3, imagem 1 %32 Samsung Galaxy J7 Vibration Motor Replacement: passo 3, imagem 2 %32 Samsung Galaxy J7 Vibration Motor Replacement: passo 3, imagem 3 %32
    • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
    • If the back panel is difficult to remove, gently heat the edges using a hair dryer or heat gun to soften the adhesive.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 18
Ao todo: 329
