Ir para o conteúdo principal
Samsung Galaxy J7 Screen Assembly Replacement
O que você precisa
  1. Samsung Galaxy J7 Screen Assembly Replacement, Back Cover: passo 1, imagem 1 %32 Samsung Galaxy J7 Screen Assembly Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the back of the device by pulling on the tab in the top left.
  2. Samsung Galaxy J7 Screen Assembly Replacement, Battery: passo 2, imagem 1 %32 Samsung Galaxy J7 Screen Assembly Replacement, Battery: passo 2, imagem 2 %32
    • Pull out the battery by pulling on the bottom left slit under the battery.
  3. Samsung Galaxy J7 Screen Assembly Replacement, Midframe: passo 3, imagem 1 %32
    • Using the Phillips #000 screwdriver, remove ten 4.2 mm screws.
  4. Samsung Galaxy J7 Screen Assembly Replacement: passo 4, imagem 1 %32 Samsung Galaxy J7 Screen Assembly Replacement: passo 4, imagem 2 %32 Samsung Galaxy J7 Screen Assembly Replacement: passo 4, imagem 3 %32
    • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
  5. Samsung Galaxy J7 Screen Assembly Replacement, Screen Assembly: passo 5, imagem 1 %32 Samsung Galaxy J7 Screen Assembly Replacement, Screen Assembly: passo 5, imagem 2 %32
    • Gently lift up the speaker piece and disconnect it from the panel.
  6. Samsung Galaxy J7 Screen Assembly Replacement: passo 6, imagem 1 %32 Samsung Galaxy J7 Screen Assembly Replacement: passo 6, imagem 2 %32
    • Gently lift up the tab of the motor.
    • Remove the motor from the panel completely to disconnect it.
  7. Samsung Galaxy J7 Screen Assembly Replacement: passo 7, imagem 1 %32
    • Reverse these steps with your new phone screen to replace it.
Conclusão
11 outras pessoas executaram este guia.
Um comentário
I replaced the broken screen....before I saw this. Now my phone will not turn on. what should I do? ruth.fnp@gmail.com
Ruth Thomas - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 100
Duração total: 10,833
