Ir para o conteúdo principal
Samsung Galaxy J7 Screen Assembly Replacement
O que você precisa
  1. Samsung Galaxy J7 Screen Assembly Replacement, Back Cover: passo 1, imagem 1 %32 Samsung Galaxy J7 Screen Assembly Replacement, Back Cover: passo 1, imagem 2 %32
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
  2. Samsung Galaxy J7 Screen Assembly Replacement, Battery: passo 2, imagem 1 %32 Samsung Galaxy J7 Screen Assembly Replacement, Battery: passo 2, imagem 2 %32
    • Locate the Battery slot: Find the small slit at the bottom right corner of the battery (highlighted by red square)
    • Remove Battery: Gently pop out the edge and carefully pull out the battery.
    • Tip: Ensure the battery is disconnected from the motherboard before removing it.
  3. Samsung Galaxy J7 Screen Assembly Replacement, Midframe: passo 3, imagem 1 %32
    • Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
  4. Samsung Galaxy J7 Screen Assembly Replacement: passo 4, imagem 1 %32 Samsung Galaxy J7 Screen Assembly Replacement: passo 4, imagem 2 %32 Samsung Galaxy J7 Screen Assembly Replacement: passo 4, imagem 3 %32
    • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
    • If the back panel is difficult to remove, gently heat the edges using a hair dryer or heat gun to soften the adhesive.
  5. Samsung Galaxy J7 Screen Assembly Replacement, Screen Assembly: passo 5, imagem 1 %32 Samsung Galaxy J7 Screen Assembly Replacement, Screen Assembly: passo 5, imagem 2 %32
    • The speaker piece is lightly adhered. Use a plastic pry tool to gently lift it up and disconnect the cable.
  6. Samsung Galaxy J7 Screen Assembly Replacement: passo 6, imagem 1 %32 Samsung Galaxy J7 Screen Assembly Replacement: passo 6, imagem 2 %32
    • Gently lift up the tab of the motor.
    • Remove the motor from the panel completely to disconnect it.
    • Removing the motor allows easier access to the screen assembly for replacement. Handle the motor and its connectors with care.
  7. Samsung Galaxy J7 Screen Assembly Replacement: passo 7, imagem 1 %32
    • Reverse these steps with your new phone screen to replace it.
    • After reassembly, test the new screen for touch responsiveness and display quality before fully securing the device
Conclusão
12 outras pessoas executaram este guia.
Um comentário
I replaced the broken screen....before I saw this. Now my phone will not turn on. what should I do? ruth.fnp@gmail.com
Ruth Thomas - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 15
Últimos 30 dias: 72
Ao todo: 11,696
