Introdução
This is a guide to replacing the battery of a Samsung Galaxy J7 Max. The replacement is very easy, due to the simple design of the phone's backing
NOTICE: If your battery looks swollen, punctured, or leaking, please refer to this article on swollen battery safety
O que você precisa
Use the indent on the right side of the phone to lift up the backing
With the phone faced downwards, remove the backing of the case, lifting up from the right side
Carefully remove the battery by lifting the bottom side, and then fully remove the battery
17 outras pessoas executaram este guia.
