Ir para o conteúdo principal
Samsung Galaxy J7 Battery Replacement
O que você precisa
  1. Samsung Galaxy J7 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Samsung Galaxy J7 Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
  2. Samsung Galaxy J7 Battery Replacement, Battery: passo 2, imagem 1 %32 Samsung Galaxy J7 Battery Replacement, Battery: passo 2, imagem 2 %32
    • Locate the Battery slot: Find the small slit at the bottom right corner of the battery (highlighted by red square)
    • Remove Battery: Gently pop out the edge and carefully pull out the battery.
    • Tip: Ensure the battery is disconnected from the motherboard before removing it.
Conclusão
11 outras pessoas executaram este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 47
Últimos 30 dias: 129
Ao todo: 12,865
