Introdução
This guide will walk you through the process of replacing a not working motherboard in a Samsung Galaxy J3V.
O que você precisa
Place your thumb on the top left corner and pry the tab open and lift off the back cover.
Remove connector tab with spudger then carefully remove headphone jack with tweezers.
7 outras pessoas executaram este guia.
