Ir para o conteúdo principal
Samsung Galaxy J3V Headphone Jack Replacement
O que você precisa
  1. Samsung Galaxy J3V Headphone Jack Replacement, Headphone Jack: passo 1, imagem 1 %32 Samsung Galaxy J3V Headphone Jack Replacement, Headphone Jack: passo 1, imagem 2 %32 Samsung Galaxy J3V Headphone Jack Replacement, Headphone Jack: passo 1, imagem 3 %32
    • Place your thumb on the top left corner and pry the tab open and lift off the back cover.
  2. Samsung Galaxy J3V Headphone Jack Replacement: passo 2, imagem 1 %32 Samsung Galaxy J3V Headphone Jack Replacement: passo 2, imagem 2 %32 Samsung Galaxy J3V Headphone Jack Replacement: passo 2, imagem 3 %32
    • Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
  3. Samsung Galaxy J3V Headphone Jack Replacement: passo 3, imagem 1 %32 Samsung Galaxy J3V Headphone Jack Replacement: passo 3, imagem 2 %32 Samsung Galaxy J3V Headphone Jack Replacement: passo 3, imagem 3 %32
    • Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
    • If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off.
  4. Samsung Galaxy J3V Headphone Jack Replacement: passo 4, imagem 1 %32 Samsung Galaxy J3V Headphone Jack Replacement: passo 4, imagem 2 %32 Samsung Galaxy J3V Headphone Jack Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove connector tab with spudger then carefully remove headphone jack with tweezers.
Conclusão
Carry Corrales
Membro desde: 09/28/17
738 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S3-G3, Nance Fall 2017 Membro de USF Tampa, Team S3-G3, Nance Fall 2017
USFT-NANCE-F17S3G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 569
