Ir para o conteúdo principal
Samsung Galaxy J3 Prime Battery and SIM Card Replacement
  1. Samsung Galaxy J3 Prime Battery and SIM Card Replacement, Battery and SIM card: passo 1, imagem 1 %32
    • Power off your phone by holding down the power button; located on the top right-hand side of your phone for approximately 5 seconds.
    • Make sure to remove your phone charger if it is plugged in.
  2. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 2, imagem 1 %32 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 2, imagem 2 %32 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 2, imagem 3 %32
    • Turn your phone so the back is facing up.
    • Using your fingers or a spudger, remove the cover by lifting it from the slot located on the top right-hand side underneath the volume buttons.
  3. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 3, imagem 1 %32 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 3, imagem 2 %32
    • Remove the battery by lifting it up from the slot in the bottom right corner.
  4. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 4, imagem 1 %32 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 4, imagem 2 %32 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 4, imagem 3 %32
    • Slide the SIM card down from the SIM card slot.
    • Make sure to firmly press down on the SIM card when sliding down, for easy removal.
  5. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 5, imagem 1 %32 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 5, imagem 2 %32
    • Slide the new SIM card into the slot.
    • When you slide the new SIM card in, make sure to place the golden pleated side face down.
    • Now place the new battery into the battery slot by aligning it correctly with the four gold contacts.
  6. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 6, imagem 1 %32 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 6, imagem 2 %32 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 6, imagem 3 %32
    • Put the cover back by sliding it on, and firmly pressing it shut.
    • Power on your phone.
Conclusão
Aisha Bashir
Membro desde: 07/01/21
133 Reputação
Autoria de 1 guia
Um comentário
I need to replace the sim card slot on one of these is it individual or does it come out with the whole motherbord and what parts do I need to order?
Mitchell Hedlund - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Duração total: 725
