Ir para o conteúdo principal
Samsung Galaxy J3 Luna Pro Headphone jack Replacement
O que você precisa
  1. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Motherboard Change: passo 1, imagem 1 %32
    • Turn off the phone.
    • Remove the back cover and battery
  2. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 2, imagem 1 %32 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 2, imagem 2 %32 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 2, imagem 3 %32
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
  3. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 3, imagem 1 %32 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 3, imagem 2 %32 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 3, imagem 3 %32
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
  4. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 4, imagem 1 %32 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 4, imagem 2 %32 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 4, imagem 3 %32
    • Remove the eleven JIS 00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
  5. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 5, imagem 1 %32 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 5, imagem 2 %32 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 5, imagem 3 %32
    • Remove the motherboard from the mid-frame.
  6. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: passo 6, imagem 1 %32 Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: passo 6, imagem 2 %32
    • Use the flat end of a spudger to pry up the headphone jack cable connector from its socket on the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Brandon Mendoza
Membro desde: 01/29/18
646 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S5-G5, Passmore Spring 2018 Membro de USF Tampa, Team S5-G5, Passmore Spring 2018
USFT-PASSMORE-S18S5G5
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,187
