O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn off the phone.
Remove the back cover and battery
Attach a suction cup to the screen and pry upwards.
Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
Use the pointy end of a spudger to remove the white plastic cover from the display cover.
Use the spudger to pry up the display cable from the motherboard.
Remove the screen.
Remove the eleven JIS 00 screws from the mid-frame.
Using a spudger, pry the mid-frame from the screen.
Use a spudger to flip up the retaining flaps on the front and rear camera ribbon cable ZIF sockets.
Pull the cables outs of the ZIF sockets.
