Introdução
Sometimes the solution to an issue with battery life is simply just a faulty battery. This guide will enable you to safely remove and replace your phone battery.
O que você precisa
Turn off the phone.
Use your thumbnail to pry off the back cover.
Remove the battery using your thumbnail.
Uma outra pessoa concluiu este guia.
