Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use a heat gun or hair dryer to heat up the front edges of the phone for about two minutes. Stay approximately six inches away from the screen to prevent phone damage.
Ferramenta utilizada nesse passo:Plastic Cards$2.99-
While the screen adhesive is still warm and flexible, insert a pry tool or plastic card between the glass display and the frame of the phone.
Slowly slide another pry tool around all the edges of the phone in order to break the adhesive's bond to the display.
Gently lift lower side and loosen all edges to hinge screen up from bottom.
Use your prying tool to slowly pry up on the bottom right corner of the white cable guard, exposing a thin ribbon cable connector.
Pry up the ribbon cable connector revealed from under the cable guard and remove the display from the device.
Clean the residue from the phone edges before re-assembling phone with new screen.
12 outras pessoas executaram este guia.
