Introdução
Use this guide to replace your motherboard. When following these steps ensure that you do not remove the glass screen from the digitizer during step four.
  1. Insert a finger nail or plastic opening tool between the back cover and the device.
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Using a finger, pull the SIM card down out of its slot.
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
    • Use the flat edge of a spudger to disconnect the ear speaker connector.
    • Use the flat end of a spudger disconnect the digitizer connector.
    • Use the flat end of a spudger disconnect the front-facing camera cable connector.
    • Remove the front-facing camera.
    • Use the flat end of a spudger to gently pry under the motherboard.
    • Remove the motherboard.
    • Use the flat end of a spudger to disconnect the rear camera cable connector.
    • Remove the rear camera.
Conclusão
7 outras pessoas concluíram este guia.
Sean Kramer
969 reputação
6 Guides authored
Equipe
USF Tampa, Team S5-G4, Eyestone Spring 2018 Membro de USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 49
Últimos 30 dias: 209
Todo: 1,612
