Ir para o conteúdo principal
Samsung Galaxy J1 Midframe Replacement
O que você precisa
  1. Samsung Galaxy J1 Midframe Replacement, Midframe: passo 1, imagem 1 %32
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Midframe Replacement: passo 2, imagem 1 %32 Samsung Galaxy J1 Midframe Replacement: passo 2, imagem 2 %32
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Midframe Replacement: passo 3, imagem 1 %32
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Midframe Replacement: passo 4, imagem 1 %32 Samsung Galaxy J1 Midframe Replacement: passo 4, imagem 2 %32 Samsung Galaxy J1 Midframe Replacement: passo 4, imagem 3 %32
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
Conclusão
6 outras pessoas executaram este guia.
Sean Kramer
Membro desde: 02/14/18
1.452 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S5-G4, Eyestone Spring 2018 Membro de USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 2,098
