Ir para o conteúdo principal
Introdução
This replacement is needed if you can't find anything else wrong with your phone but it still won't work.
  1. Remove the back cover of phone by lifting up on the back cover tab with  the blue plastic opening tool. Go around the edge of the back cover to completely remove it. Go around the edge of the back cover to completely remove it.
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Remove the old battery by lifting up on  the thumb tab. Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections. Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver. Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver. Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Wedge the blue plastic opening tool in between the front and side panel. Move the blue plastic opening tool around the edges between the front and side panel.
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Make sure that you detach the mid-frame from the inside too. Make sure that you detach the mid-frame from the inside too.
    • Make sure that you detach the mid-frame from the inside too.
  6. Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack. Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
  7. Use the plastic opening tool to unhook the ribbon cable clip. Use the plastic opening tool to unhook the ribbon cable clip.
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Gently pull on the connector with the tweezers until the speaker comes off. Gently pull on the connector with the tweezers until the speaker comes off.
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Unhook the other ribbon cable clip to the screen with the blue plastic opening tool. Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Unhook the ribbon cable clip to the front camera. Lift the motherboard up and out of the device. Lift the motherboard up and out of the device.
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Remove the motherboard and unhook the ribbon cable clip to the back camera. Remove the motherboard and unhook the ribbon cable clip to the back camera.
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
Conclusão
78 outras pessoas concluíram este guia.
Kyle Ruff
Membro desde: 04/02/2016
6.291 Reputação
5 Guias de autoria
Equipe
USF Tampa, Team 17-3, Blackwell Winter 2016 Membro de USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Membros
6 Guias de autoria
After fixing all the screen, for some reason the LCD was turning on but it showed black and i dont know if is because im missing a screw or because the LCD doesnt work?
Glo - Responder
lol this is likely because you ruined the lcd. this tutorial forgot to mention that it is essential to apply heat, as the midframe is adhered on to the inner component.
connectedcellrepair -
Just need to get a idea on this phone, the silver backing thats usually stuck to the mid frame, when pulling out the old lcd this also came with it.
My question is whether or not that needs to replaced?
Also it changes screens all on its on.
Lisa Yates - Responder
My grand prime 4g board damage
Rakesh - Responder
My grand prime 4g mother board damage
Rakesh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 126
Duração total: 49,336
