Ir para o conteúdo principal
Samsung Galaxy Grand Prime Micro USB Port Replacement
O que você precisa
  1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: passo 1, imagem 2 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: passo 1, imagem 3 %32
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: passo 2, imagem 1 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: passo 2, imagem 2 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: passo 2, imagem 3 %32
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: passo 3, imagem 1 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: passo 3, imagem 2 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: passo 3, imagem 3 %32
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 4, imagem 1 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 4, imagem 2 %32
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 5, imagem 1 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 5, imagem 2 %32
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: passo 6, imagem 1 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: passo 6, imagem 2 %32
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
  7. Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: passo 7, imagem 1 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: passo 7, imagem 2 %32
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 8, imagem 1 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: passo 9, imagem 1 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: passo 9, imagem 2 %32
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 10, imagem 1 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 10, imagem 2 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 10, imagem 3 %32
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 11, imagem 1 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 11, imagem 2 %32
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
  12. Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: passo 12, imagem 1 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: passo 12, imagem 2 %32 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: passo 12, imagem 3 %32
    • Using a soldering iron to solder off the charging port.
    • Be careful soldering iron gets extremely hot.
Conclusão
33 outras pessoas executaram este guia.
Kyle Ruff
Membro desde: 02/04/16
6.749 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 17-3, Blackwell Winter 2016 Membro de USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 53
Duração total: 34,895
