Ir para o conteúdo principal
Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement
O que você precisa
  1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: passo 1, imagem 2 %32 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: passo 1, imagem 3 %32
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: passo 2, imagem 1 %32 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: passo 2, imagem 2 %32 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: passo 2, imagem 3 %32
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: passo 3, imagem 1 %32 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: passo 3, imagem 2 %32 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: passo 3, imagem 3 %32
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: passo 4, imagem 1 %32 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: passo 4, imagem 2 %32
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: passo 5, imagem 1 %32 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: passo 5, imagem 2 %32
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: passo 6, imagem 1 %32 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: passo 6, imagem 2 %32
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
Conclusão
30 outras pessoas executaram este guia.
Kyle Ruff
Membro desde: 02/04/16
6.749 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 17-3, Blackwell Winter 2016 Membro de USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
Membros da 3
Autoria de 12 guias
3 comentários
i seem to find myself with the speaker of microphone connected to the back of the housing.. where as i see your photo in step 5 does't have this. how can I replace this element?
jennpindakaas - Responder
I do this but i think my circuit have problem. When i insert aux, the sound play mono. The phone setting is stereo…..
How can i fix this problem?
Replay me on rabbanihootan71@gmail.com
Hootan Rabbani - Responder
How to me a memory card a default storage on grand prime
Ayandaundetsco - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 37
Duração total: 36,027
