Ir para o conteúdo principal
Samsung Galaxy Grand Prime Battery Replacement
O que você precisa
  1. Samsung Galaxy Grand Prime Battery Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Grand Prime Battery Replacement, Battery: passo 1, imagem 2 %32 Samsung Galaxy Grand Prime Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Battery Replacement, Remove the battery.: passo 2, imagem 1 %32 Samsung Galaxy Grand Prime Battery Replacement, Remove the battery.: passo 2, imagem 2 %32 Samsung Galaxy Grand Prime Battery Replacement, Remove the battery.: passo 2, imagem 3 %32
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
Conclusão
51 outras pessoas executaram este guia.
Damien Harris
Membro desde: 02/04/16
978 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 17-3, Blackwell Winter 2016 Membro de USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
Membros da 3
Autoria de 12 guias
Um comentário
Should I assume that it is the battery at fault when about 3 location seems a bit warm on the board when leaving the charger on?
Noelu Toyotomi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 120
Duração total: 13,971
