Ir para o conteúdo principal
Samsung Galaxy Fame S6812i Motherboard Replacement
O que você precisa
  1. Samsung Galaxy Fame S6812i Motherboard Replacement, Remove Battery Cover: passo 1, imagem 1 %32 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove Battery Cover: passo 1, imagem 2 %32
    • Locate the small indent in the top of the device and use your nails or a spudger to separate the cover from the mid-frame.
  2. Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Battery: passo 2, imagem 1 %32 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Battery: passo 2, imagem 2 %32
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Mid-Frame: passo 3, imagem 1 %32 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Mid-Frame: passo 3, imagem 2 %32 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Mid-Frame: passo 3, imagem 3 %32
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  4. Samsung Galaxy Fame S6812i Motherboard Replacement, Unplug LCD Screen from Motherboard: passo 4, imagem 1 %32 Samsung Galaxy Fame S6812i Motherboard Replacement, Unplug LCD Screen from Motherboard: passo 4, imagem 2 %32 Samsung Galaxy Fame S6812i Motherboard Replacement, Unplug LCD Screen from Motherboard: passo 4, imagem 3 %32
    • Locate the two ribbon cable connections on the motherboard. GENTLY use the pointed end of the spudger to disconnect the cables. Lift the motherboard out of the phone.
  5. Samsung Galaxy Fame S6812i Motherboard Replacement: passo 5, imagem 1 %32
    • Using your fingers or a plastic opening tool, carefully lift the motherboard assembly from the phone.
  6. Samsung Galaxy Fame S6812i Motherboard Replacement, Chassis Removal: passo 6, imagem 1 %32 Samsung Galaxy Fame S6812i Motherboard Replacement, Chassis Removal: passo 6, imagem 2 %32
    • On the front face of the motherboard, locate the two #00 Phillips head screws. These hold the SIM card chassis in place.
    • Keep these screws separate from the back plate screws.
Conclusão
5 outras pessoas executaram este guia.
Taylor
Membro desde: 01/30/15
1.165 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-6, Watkins Winter 2015 Membro de USF Tampa, Team 16-6, Watkins Winter 2015
USFT-WATKINS-W15S16G6
Membros da 2
Autoria de 5 guias
Um comentário
How to jumper network problem
Kshitiz khadka - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 12
Duração total: 1,196
