Ir para o conteúdo principal
Samsung Galaxy Fame S6812i Midframe Replacement
O que você precisa
  1. Samsung Galaxy Fame S6812i Midframe Replacement, Remove back cover: passo 1, imagem 1 %32
    • Start by removing the back cover by using your thumbnail to pry the cover off the midframe.
  2. Samsung Galaxy Fame S6812i Midframe Replacement: passo 2, imagem 1 %32 Samsung Galaxy Fame S6812i Midframe Replacement: passo 2, imagem 2 %32 Samsung Galaxy Fame S6812i Midframe Replacement: passo 2, imagem 3 %32
    • Note: one of the screws is hidden under a plastic sticker.
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
  3. Samsung Galaxy Fame S6812i Midframe Replacement: passo 3, imagem 1 %32
    • Remove the battery with plastic opening tool
  4. Samsung Galaxy Fame S6812i Midframe Replacement, Separating the midframe: passo 4, imagem 1 %32 Samsung Galaxy Fame S6812i Midframe Replacement, Separating the midframe: passo 4, imagem 2 %32
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Midframe Replacement, Final step: passo 5, imagem 1 %32
    • Once you have separated the mid-frame it should look like this.
    • Replace the old mid-frame with the new one and follow the steps in reverse.
Conclusão
Uma outra pessoa concluiu este guia.
Charles
Membro desde: 10/07/14
133 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 8-2, Leahy Fall 2014 Membro de USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 574
