Ir para o conteúdo principal
Samsung Galaxy Fame S6812i Camera Replacement
O que você precisa
  1. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery cover: passo 1, imagem 1 %32
    • Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
  2. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery: passo 2, imagem 1 %32
    • Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
  3. Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: passo 3, imagem 1 %32 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: passo 3, imagem 2 %32 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: passo 3, imagem 3 %32
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
    • Make sure you remove the sticker hiding the screw on the left bottom corner.
  4. Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: passo 4, imagem 1 %32 Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: passo 4, imagem 2 %32
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Camera Replacement: passo 5, imagem 1 %32
    • After separating the two frames, you will have access to the camera
  6. Samsung Galaxy Fame S6812i Camera Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull the camera off the system by using the tweezers. Perform this step with caution.
Conclusão
6 outras pessoas executaram este guia.
Charles
Membro desde: 10/07/14
133 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 8-2, Leahy Fall 2014 Membro de USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 1,005
