Ir para o conteúdo principal
Samsung Galaxy Express 3 Screen Replacement
O que você precisa
  1. Samsung Galaxy Express 3 Screen Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Express 3 Screen Replacement, Battery: passo 1, imagem 2 %32
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Screen Replacement: passo 2, imagem 1 %32 Samsung Galaxy Express 3 Screen Replacement: passo 2, imagem 2 %32 Samsung Galaxy Express 3 Screen Replacement: passo 2, imagem 3 %32
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Screen Replacement, Screen: passo 3, imagem 1 %32 Samsung Galaxy Express 3 Screen Replacement, Screen: passo 3, imagem 2 %32
    • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
  4. Samsung Galaxy Express 3 Screen Replacement: passo 4, imagem 1 %32
    • Detach the screen connector.
  5. Samsung Galaxy Express 3 Screen Replacement: passo 5, imagem 1 %32 Samsung Galaxy Express 3 Screen Replacement: passo 5, imagem 2 %32
    • Use a blow dryer or heating pad to heat up the screen.
    • Do not skip this step, as it may result in a broken screen and/or LCD.
    • This step loosens the glue holding the screen in place.
    How much time does it take
    David Sapp - Responder
  6. Samsung Galaxy Express 3 Screen Replacement: passo 6, imagem 1 %32 Samsung Galaxy Express 3 Screen Replacement: passo 6, imagem 2 %32 Samsung Galaxy Express 3 Screen Replacement: passo 6, imagem 3 %32
    • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
    • Do this slowly and carefully, as both parts can crack very easily.
    • Ensure your tool is plastic, as a metal tool can damage the screen easily.
Conclusão
7 outras pessoas executaram este guia.
2 comentários
My friend set on his phone the screen is broken. The phone will come on but the screen will not light up.
Rudolph Mc Alister - Responder
Same! For TWO phones now… have you had any luck on any suggestions or figuring anything out???
Faith Dockery -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 3,471
