Ir para o conteúdo principal
Samsung Galaxy Express 3 Rear Camera Lens Replacement
O que você precisa
  1. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: passo 1, imagem 2 %32
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Rear Camera Lens Replacement: passo 2, imagem 1 %32 Samsung Galaxy Express 3 Rear Camera Lens Replacement: passo 2, imagem 2 %32 Samsung Galaxy Express 3 Rear Camera Lens Replacement: passo 2, imagem 3 %32
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Rear Camera Lens: passo 3, imagem 1 %32
    • Carefully push a small pointed tool such as a plastic opening tool (or metal spudger if needed) underneath the camera lens in a corner.
    • Pry up each corner of the lens.
    • Be careful, especially if using the metal spudger, as if you push to hard it can cause damage to the device or yourself.
  4. Samsung Galaxy Express 3 Rear Camera Lens Replacement: passo 4, imagem 1 %32 Samsung Galaxy Express 3 Rear Camera Lens Replacement: passo 4, imagem 2 %32
    • Slide your tool underneath one corner to the other to release the lens.
    • Make sure not to insert your tool too far as it can damage the camera.
    • When putting the new lens in make sure not to put to much force on it as it can break again.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 515
