Ir para o conteúdo principal
Samsung Galaxy Core Screen Replacement
O que você precisa
  1. Samsung Galaxy Core Screen Replacement, Screen: passo 1, imagem 1 %32 Samsung Galaxy Core Screen Replacement, Screen: passo 1, imagem 2 %32 Samsung Galaxy Core Screen Replacement, Screen: passo 1, imagem 3 %32
    • Flip the phone over and use your fingernail or an opening tool to remove the back cover.
  2. Samsung Galaxy Core Screen Replacement: passo 2, imagem 1 %32 Samsung Galaxy Core Screen Replacement: passo 2, imagem 2 %32
    • Remove the battery.
    • If your phone has a SIM card or MicroSD card, remove them.
  3. Samsung Galaxy Core Screen Replacement: passo 3, imagem 1 %32
    • Remove the 9 Phillips #00 screws from the mid-frame.
  4. Samsung Galaxy Core Screen Replacement: passo 4, imagem 1 %32 Samsung Galaxy Core Screen Replacement: passo 4, imagem 2 %32
    • Use an opening pick to pry off the mid frame.
  5. Samsung Galaxy Core Screen Replacement: passo 5, imagem 1 %32 Samsung Galaxy Core Screen Replacement: passo 5, imagem 2 %32
    • Disconnect the following ribbon cables from the motherboard:
    • The digitizer and LCD assembly.
    • Headphone Jack and Earpiece.
    • Daughter board flex cable.
    • Antenna connector.
  6. Samsung Galaxy Core Screen Replacement: passo 6, imagem 1 %32 Samsung Galaxy Core Screen Replacement: passo 6, imagem 2 %32 Samsung Galaxy Core Screen Replacement: passo 6, imagem 3 %32
    • Use a plastic opening tool to remove the motherboard.
  7. Samsung Galaxy Core Screen Replacement: passo 7, imagem 1 %32 Samsung Galaxy Core Screen Replacement: passo 7, imagem 2 %32 Samsung Galaxy Core Screen Replacement: passo 7, imagem 3 %32
    • Remove the single Phillips screw that secures the daughterboard.
    • Remove the daughterboard.
    • The flex cable is glued, so exercise extreme caution, as excessive force can damage the cable.
  8. Samsung Galaxy Core Screen Replacement: passo 8, imagem 1 %32 Samsung Galaxy Core Screen Replacement: passo 8, imagem 2 %32 Samsung Galaxy Core Screen Replacement: passo 8, imagem 3 %32
    • Use an opening pick to remove the audio jack.
  9. Samsung Galaxy Core Screen Replacement: passo 9, imagem 1 %32 Samsung Galaxy Core Screen Replacement: passo 9, imagem 2 %32
    • Disconnect the digitizer's ribbon cable.
  10. Samsung Galaxy Core Screen Replacement: passo 10, imagem 1 %32
    • Push the earpiece mesh outwards to release it.
  11. Samsung Galaxy Core Screen Replacement: passo 11, imagem 1 %32
    • Use a heat gun or an iOpener to heat the digitizer and soften the glue securing it.
    • Use an opening pick to break up the glue around the edges of the digitizer.
    • You may apply more heat if needed.
    • Remove the digitizer and any broken glass.
Conclusão
90 outras pessoas executaram este guia.
ivan coene
Membro desde: 03/12/14
3.006 Reputação
Autoria de 2 guias
11 comentários
yes, but where can I buy the screen replacement?
Roxannie - Responder
I bought it on Ebay...
ivan coene - Responder
Comment root galaxy core prime g361f android 5.1.1
soulaemen - Responder
Follow the instructions in reverse order? Do you need glue for the new screen? What kind of glue? How is it applied?
Thomas McGuigan - Responder
Nor do they show how the new digitizer plugs in...
chris smith -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 116,997
