Ir para o conteúdo principal
Samsung Galaxy Core Prime Volume Buttons Replacement
O que você precisa
  1. Samsung Galaxy Core Prime Volume Buttons Replacement, Battery: passo 1, imagem 1 %32
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Volume Buttons Replacement: passo 2, imagem 1 %32
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Volume Buttons Replacement: passo 3, imagem 1 %32
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Volume Buttons Replacement: passo 4, imagem 1 %32 Samsung Galaxy Core Prime Volume Buttons Replacement: passo 4, imagem 2 %32
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Volume Buttons Replacement: passo 5, imagem 1 %32
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Volume Buttons Replacement, Volume Button: passo 6, imagem 1 %32 Samsung Galaxy Core Prime Volume Buttons Replacement, Volume Button: passo 6, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the eight 4mm screws from the midframe.
  7. Samsung Galaxy Core Prime Volume Buttons Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    iOpener
    $24.95
    • Flip the phone over (screen up). Use an iOpener to heat the frame. Do this until the adhesive is loose.
    • Use care when handling these heating tools!
  8. Samsung Galaxy Core Prime Volume Buttons Replacement: passo 8, imagem 1 %32 Samsung Galaxy Core Prime Volume Buttons Replacement: passo 8, imagem 2 %32
    iFixit Opening Tool
    $1.99
    • Use an iFixit Opening Tool or a similarly shaped tool like a guitar pick to lift the mid-frame.
  9. Samsung Galaxy Core Prime Volume Buttons Replacement: passo 9, imagem 1 %32 Samsung Galaxy Core Prime Volume Buttons Replacement: passo 9, imagem 2 %32
    • Use tweezers to unhook both of the rubber fixtures holding the volume button to the frame.
Conclusão
3 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 57
Ao todo: 1,246
