Ir para o conteúdo principal
Samsung Galaxy Core Prime Screen Replacement
O que você precisa
  1. Samsung Galaxy Core Prime Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Screen Replacement: passo 2, imagem 1 %32
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Screen Replacement: passo 3, imagem 1 %32
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Screen Replacement: passo 4, imagem 1 %32 Samsung Galaxy Core Prime Screen Replacement: passo 4, imagem 2 %32
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Screen Replacement: passo 5, imagem 1 %32
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Screen Replacement, Screen: passo 6, imagem 1 %32 Samsung Galaxy Core Prime Screen Replacement, Screen: passo 6, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the eight 4 mm screws from the midframe.
  7. Samsung Galaxy Core Prime Screen Replacement: passo 7, imagem 1 %32
    • Use a heat gun or hair dryer to loosen the adhesive between the midframe and the rest of the device.
    • Take care when using these heat tools.
  8. Samsung Galaxy Core Prime Screen Replacement: passo 8, imagem 1 %32 Samsung Galaxy Core Prime Screen Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    iFixit Opening Tool
    $1.99
    Comprar
  9. Samsung Galaxy Core Prime Screen Replacement: passo 9, imagem 1 %32 Samsung Galaxy Core Prime Screen Replacement: passo 9, imagem 2 %32
    • Use tweezers to disconnect the power ribbon from the motherboard.
  10. Samsung Galaxy Core Prime Screen Replacement: passo 10, imagem 1 %32 Samsung Galaxy Core Prime Screen Replacement: passo 10, imagem 2 %32
    • Use tweezers or your hand to remove the audiojack.
  11. Samsung Galaxy Core Prime Screen Replacement: passo 11, imagem 1 %32
    iFixit Opening Tool
    $1.99
    Comprar
  12. Samsung Galaxy Core Prime Screen Replacement: passo 12, imagem 1 %32
    iFixit Opening Tool
    $1.99
    Comprar
    • Lift the plastic panel that separates the digitizer and the motherboard with an iFixit Opening Tool
  13. Samsung Galaxy Core Prime Screen Replacement: passo 13, imagem 1 %32 Samsung Galaxy Core Prime Screen Replacement: passo 13, imagem 2 %32 Samsung Galaxy Core Prime Screen Replacement: passo 13, imagem 3 %32
    iFixit Opening Tool
    $1.99
    Comprar
  14. Samsung Galaxy Core Prime Screen Replacement: passo 14, imagem 1 %32 Samsung Galaxy Core Prime Screen Replacement: passo 14, imagem 2 %32
    • Use tweezers to disconnect the digitizer.
Conclusão
7 outras pessoas executaram este guia.
Cody Coombs
Membro desde: 10/02/18
257 Reputação
Autoria de 1 guia
Equipe
Um comentário
What if the phone does not come back on after assembly
nfl.ny.la.313 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 38
Duração total: 2,485
