Introdução
A common problem you may have with the Samsung Galaxy Core Prime is a sticky or broken home button. Rather than go somewhere to fix it you can use this guide to help you remove or readjust the button. You will need tweezers, a heat gun or hair dryer, a Phillips #00 screwdriver, and an iFixit Opening Tool.
Ferramentas
Peças
Nenhum componente especificado.
Use a flat tool or the iFixit Opening Tool to lift the midframe.
Lift the motherboard out using the iFixit Opening Tool.
Use the iFixit Opening Tool to remove the plastic panel that separates the motherboard and the screen.
