Ir para o conteúdo principal
Samsung Galaxy Core Prime Home Button Replacement
O que você precisa
  1. Samsung Galaxy Core Prime Home Button  Replacement, Battery: passo 1, imagem 1 %32
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Home Button  Replacement: passo 2, imagem 1 %32
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Home Button  Replacement: passo 3, imagem 1 %32
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Home Button  Replacement: passo 4, imagem 1 %32 Samsung Galaxy Core Prime Home Button  Replacement: passo 4, imagem 2 %32
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Home Button  Replacement: passo 5, imagem 1 %32
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Home Button  Replacement, Home Button: passo 6, imagem 1 %32
    • Use your thumb to remove the sim card.
  7. Samsung Galaxy Core Prime Home Button  Replacement: passo 7, imagem 1 %32 Samsung Galaxy Core Prime Home Button  Replacement: passo 7, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws that secure the midframe.
  8. Samsung Galaxy Core Prime Home Button  Replacement: passo 8, imagem 1 %32
    • Heat the frame with a hair dryer or heat gun. Do this until the adhesive is loosened.
    • Take care when using these heating tools.
  9. Samsung Galaxy Core Prime Home Button  Replacement: passo 9, imagem 1 %32
    Ferramenta utilizada neste passo:
    iFixit Opening Tool
    $1.99
  10. Samsung Galaxy Core Prime Home Button  Replacement: passo 10, imagem 1 %32 Samsung Galaxy Core Prime Home Button  Replacement: passo 10, imagem 2 %32
    • Disconnect the LCD screen/touch screen ribbon from the motherboard using tweezers.
  11. Samsung Galaxy Core Prime Home Button  Replacement: passo 11, imagem 1 %32
    iFixit Opening Tool
    $1.99
  12. Samsung Galaxy Core Prime Home Button  Replacement: passo 12, imagem 1 %32
    • Heat the sides of the screen with a heat gun or hair dryer.
  13. Samsung Galaxy Core Prime Home Button  Replacement: passo 13, imagem 1 %32
    iFixit Opening Tool
    $1.99
    • Use the iFixit Opening Tool to remove the plastic panel that separates the motherboard and the screen.
  14. Samsung Galaxy Core Prime Home Button  Replacement: passo 14, imagem 1 %32
    • Use tweezers to remove the home button.
Conclusão
Uma outra pessoa concluiu este guia.
Kate Vogel
Membro desde: 10/02/18
187 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 61
Ao todo: 1,841
