Ir para o conteúdo principal
Samsung Galaxy Core Prime Back Camera Replacement
O que você precisa
  1. Samsung Galaxy Core Prime Back Camera Replacement, Battery: passo 1, imagem 1 %32
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Back Camera Replacement: passo 2, imagem 1 %32
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Back Camera Replacement: passo 3, imagem 1 %32
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Back Camera Replacement: passo 4, imagem 1 %32 Samsung Galaxy Core Prime Back Camera Replacement: passo 4, imagem 2 %32
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Back Camera Replacement: passo 5, imagem 1 %32
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Back Camera Replacement, Rear Camera: passo 6, imagem 1 %32 Samsung Galaxy Core Prime Back Camera Replacement, Rear Camera: passo 6, imagem 2 %32
    • Use a Phillips #00 screw driver to remove all eight 4mm screws from the midframe.
  7. Samsung Galaxy Core Prime Back Camera Replacement: passo 7, imagem 1 %32
    • Heat the frame with a heat gun or hair dryer until the adhesive is loose.
    • Take care when using these heat tools.
  8. Samsung Galaxy Core Prime Back Camera Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    iFixit Opening Tool
    $1.99
  9. Samsung Galaxy Core Prime Back Camera Replacement: passo 9, imagem 1 %32 Samsung Galaxy Core Prime Back Camera Replacement: passo 9, imagem 2 %32
    • Disconnect the power ribbon on the left side of the phone either with your fingers or tweezers
  10. Samsung Galaxy Core Prime Back Camera Replacement: passo 10, imagem 1 %32
    iFixit Opening Tool
    $1.99
  11. Samsung Galaxy Core Prime Back Camera Replacement: passo 11, imagem 1 %32 Samsung Galaxy Core Prime Back Camera Replacement: passo 11, imagem 2 %32
    Metal Spudger
    $2.99
    • Turn the Motherboard over and disconnect the ribbon connecting the camera to the Motherboard with an iFixit Metal Spudger.
Conclusão
3 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 7
Últimos 30 dias: 21
Ao todo: 1,725
