Introdução
Follow this guide to replace the entire motherboard in a Samsung Galaxy Core Plus.
O que você precisa
Insert the flat side of a spudger into the gap next to the power button.
The back cover is held by plastic clips. Pry the cover away from the phone until the clips release.
Insert the flat end of a spudger into the gap at the bottom of the battery.
Pry the battery up and away from the phone.
Grab the battery and lift it out of the phone.
Use a Phillips #00 screwdriver to remove eleven T3 screws from the midframe.
There are eight 4mm screws on the left and bottom of the midframe.
There are three 3.9mm screws in the upper right of the midframe.
Heat an iOpener and apply it to the front of the device for two minutes. This will loosen the adhesive around the perimeter of the screen.
Insert a spudger under the midframe and pry upward.
You may pry along any side of the battery recess. The right side and top side will be the easiest.
Once the adhesive between the midframe and screen has been cut, the midframe will be free.
Grab and pull the midframe away from the phone.
Use a spudger to release the press-fit connector from the motherboard.
Using a pair of blunt-nose tweezers or your fingers, remove the headphone jack.
Use a spudger to flick open the press-fit connector located in the upper right of the phone.
Simply grab and lift the motherboard from the phone. There are no screws or cables holding it in place.
Uma outra pessoa concluiu este guia.
