O que você precisa
Remove the touchscreen with thin tools between the glass and the central cover with the aid of a hair dryer or heat so that you can loosen the adhesive grip
Be careful in the part of the buttons and the flat cable of the touchscreen if you need to use it again and do not replace it with a new one
To Reassemble your device, Follow these instruction reverse order.
3 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
irlanda está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
