Ir para o conteúdo principal
Samsung Galaxy Centura Lock and Volume Buttons Replacement
O que você precisa
  1. Samsung Galaxy Centura Lock and Volume Buttons Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Centura Lock and Volume Buttons Replacement, Battery: passo 1, imagem 2 %32
    • Locate the rectangular groove on the top side of the device.
    • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
  2. Samsung Galaxy Centura Lock and Volume Buttons Replacement: passo 2, imagem 1 %32 Samsung Galaxy Centura Lock and Volume Buttons Replacement: passo 2, imagem 2 %32 Samsung Galaxy Centura Lock and Volume Buttons Replacement: passo 2, imagem 3 %32
    • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
    • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
  3. Samsung Galaxy Centura Lock and Volume Buttons Replacement, Lock and Volume Buttons: passo 3, imagem 1 %32
    • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
  4. Samsung Galaxy Centura Lock and Volume Buttons Replacement: passo 4, imagem 1 %32 Samsung Galaxy Centura Lock and Volume Buttons Replacement: passo 4, imagem 2 %32
    • Locate the indentation on the side of the device, and gently insert the plastic opening tool into it. With a firm prying motion, the plastic should begin to come apart.
  5. Samsung Galaxy Centura Lock and Volume Buttons Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Locate the volume buttons on the plastic casing.
    • Gently pull the black tab up and out with the tweezers, then push or pull the button inward and out of the plastic casing. It should come free without resistance.
  6. Samsung Galaxy Centura Lock and Volume Buttons Replacement: passo 6, imagem 1 %32 Samsung Galaxy Centura Lock and Volume Buttons Replacement: passo 6, imagem 2 %32
    • Locate the lock button on the opposite side of the plastic casing.
    • Using the tweezers, pull the two horizontal tabs up and out of the plastic pegs that hold them in place.
    • Push the button inward and out of the plastic casing. This may require firm pressure to free it completely.
Conclusão
Austin Erickson
Membro desde: 02/28/17
354 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S2-G5, Nance Spring 2017 Membro de USF Tampa, Team S2-G5, Nance Spring 2017
USFT-NANCE-S17S2G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 242
