Ir para o conteúdo principal
Samsung Galaxy Camera Lens or Motherboard Replacement
O que você precisa
  1. Samsung Galaxy Camera Lens or Motherboard Replacement, Lens or Motherboard: passo 1, imagem 1 %32
    • Gather your camera and tools. Also make sure that the battery is removed before proceeding.
    • Follow battery replacement guide through step three to remove the battery.
  2. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 2, imagem 1 %32 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 2, imagem 2 %32 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 2, imagem 3 %32
    • Remove all seven 4 millimeter long screws using the PH000 screwdriver bit.
  3. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 3, imagem 1 %32 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 3, imagem 2 %32
    • Use plastic opening tool to remove the cover on the non-lens side of the camera.
  4. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 4, imagem 1 %32 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 4, imagem 2 %32 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 4, imagem 3 %32
    • Open the battery compartment and remove the 2 screws. Also remove the screw from the bottom of the camera after pulling off the white sticker concealing it. Removing these screws releases the bottom of the display assembly.
    • Starting at the non-lens side of the camera, use plastic opening tool to pry screen away from main housing on all sides.
  5. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 5, imagem 1 %32 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 5, imagem 2 %32
    • Use plastic opening tool to pull connector away from motherboard.
    • Remove screen completely and set aside.
  6. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 6, imagem 1 %32 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 6, imagem 2 %32
    • Using the plastic opening tool, disconnect the three connectors from the motherboard.
  7. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the three 3.5 mm long screws (red circle markers) using the PH000 screwdriver bit.
    • Remove the four 2 mm long screws (orange circle markers) using the PH000 screwdriver bit.
  8. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 8, imagem 1 %32 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the three 3 mm long screws connecting the lens unit to the main housing using the PH000 screwdriver bit.
    • Carefully remove the lens and motherboard from main housing.
  9. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 9, imagem 1 %32 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 9, imagem 2 %32 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 9, imagem 3 %32
    • Remove stickers off of connectors.
    • Open latch door on connectors.
    • Separate lens from motherboard.
    • Now you may replace either motherboard or lens with new part.
Conclusão
8 outras pessoas executaram este guia.
Keith Lipking
Membro desde: 09/26/15
359 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-3, Wilson Fall 2015 Membro de IUPUI, Team 2-3, Wilson Fall 2015
IUPUI-WILSON-F15S2G3
Membros da 4
Autoria de 4 guias
2 comentários
Would love a video of this, as well.
David CrossmN - Responder
Hey after you replace the motherboard do you just turn the camera on and it works?
Ive done it and some chinese characters show up in a dialog box...
Sam - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 24
Duração total: 3,375
