Introdução
In this guide, you will learn how to replace the battery in your Samsung Galaxy Camera 2.
Replacing the battery of the camera can fix a number of problems, including the camera not holding a charge, the camera not charging, or the camera not powering on. Removing the battery is also a necessary step in disassembling the camera for other repairs.
O que você precisa
Face the camera towards you, then rotate it such that the battery door is facing up and to the right.
5 outras pessoas executaram este guia.
