Ir para o conteúdo principal
Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement
O que você precisa
  1. Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement, Access the rubber feet: passo 1, imagem 1 %32 Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement, Access the rubber feet: passo 1, imagem 2 %32
    • Before you begin, shut down your laptop and unplug it.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement, Remove the rubber feet: passo 2, imagem 1 %32 Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement, Remove the rubber feet: passo 2, imagem 2 %32 Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement, Remove the rubber feet: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Insert an opening pick between the rear case and the rubber foot.
    • Pry up with the pick and dislodge the foot from the rear case.
    • Use tweezers or your fingers to remove the rubber foot.
    • Repeat this process on the remaining rubber feet.
    • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
    • To reinstall a rubber foot, align it over the recess and push down until it's secured.
Conclusão
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Spencer Day
Membro desde: 09/14/22
55.203 Reputação
Autoria de 408 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.430 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 47
Duração total: 1,290
