Ir para o conteúdo principal
Samsung Galaxy Book Pro 360 15" Rear Case Replacement
O que você precisa
  1. Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Access the rubber feet: passo 1, imagem 1 %32 Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Access the rubber feet: passo 1, imagem 2 %32
    • Before you begin, shut down your laptop and unplug it.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Remove the rubber feet: passo 2, imagem 1 %32 Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Remove the rubber feet: passo 2, imagem 2 %32 Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Remove the rubber feet: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Insert an opening pick between the rear case and the rubber foot.
    • Pry up with the pick and dislodge the foot from the rear case.
    • Use tweezers or your fingers to remove the rubber foot.
    • Repeat this process on the remaining rubber feet.
    • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
    • To reinstall a rubber foot, align it over the recess and push down until it's secured.
  3. Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Unfasten the rear case: passo 3, imagem 1 %32 Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Unfasten the rear case: passo 3, imagem 2 %32
    Magnetic Project Mat
    $19.95
    Comprar
    • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3313.
  4. Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Insert an opening pick: passo 4, imagem 1 %32 Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Insert an opening pick: passo 4, imagem 2 %32 Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Insert an opening pick: passo 4, imagem 3 %32
    • Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
    • Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
    • This may take significant force and multiple tries.
    • Insert an opening pick into the gap you created.
  5. Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Release the clips: passo 5, imagem 1 %32 Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Release the clips: passo 5, imagem 2 %32 Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Release the clips: passo 5, imagem 3 %32
    • Slide the opening pick along the bottom edge to release the clips securing the rear case.
    • Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
  6. Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Remove the rear case: passo 6, imagem 1 %32 Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Remove the rear case: passo 6, imagem 2 %32 Samsung Galaxy Book Pro 360 15" Rear Case Replacement, Remove the rear case: passo 6, imagem 3 %32
    • Lift the rear case up and away from the laptop and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Conclusão
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Uma outra pessoa concluiu este guia.
Spencer Day
Membro desde: 09/14/22
55.203 Reputação
Autoria de 408 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.430 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 76
Duração total: 1,661
