Ir para o conteúdo principal
Samsung Galaxy Book Pro 15" Rubber Feet Replacement
O que você precisa
  1. Samsung Galaxy Book Pro 15" Rubber Feet Replacement, Remove the rubber feet: passo 1, imagem 1 %32 Samsung Galaxy Book Pro 15" Rubber Feet Replacement, Remove the rubber feet: passo 1, imagem 2 %32 Samsung Galaxy Book Pro 15" Rubber Feet Replacement, Remove the rubber feet: passo 1, imagem 3 %32
    • Before you begin, power down your laptop and unplug it.
    • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
    • Insert an opening pick between the rubber foot and the rear case.
    • Pry up with the opening pick to release the clips securing the foot.
    • Remove the foot.
    • Repeat this procedure for the three remaining feet.
    • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
Conclusão
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
125.025 Reputação
Autoria de 582 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.430 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Duração total: 736
