Ir para o conteúdo principal
Samsung Galaxy Amp 2 Screen Replacement
O que você precisa
  1. Samsung Galaxy Amp 2 Screen Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Amp 2 Screen Replacement, Battery: passo 1, imagem 2 %32
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. Samsung Galaxy Amp 2 Screen Replacement: passo 2, imagem 1 %32 Samsung Galaxy Amp 2 Screen Replacement: passo 2, imagem 2 %32 Samsung Galaxy Amp 2 Screen Replacement: passo 2, imagem 3 %32
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
  3. Samsung Galaxy Amp 2 Screen Replacement, Screen: passo 3, imagem 1 %32 Samsung Galaxy Amp 2 Screen Replacement, Screen: passo 3, imagem 2 %32 Samsung Galaxy Amp 2 Screen Replacement, Screen: passo 3, imagem 3 %32
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
  4. Samsung Galaxy Amp 2 Screen Replacement: passo 4, imagem 1 %32
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
  5. Samsung Galaxy Amp 2 Screen Replacement: passo 5, imagem 1 %32 Samsung Galaxy Amp 2 Screen Replacement: passo 5, imagem 2 %32 Samsung Galaxy Amp 2 Screen Replacement: passo 5, imagem 3 %32
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
Conclusão
6 outras pessoas executaram este guia.
Cory Nickolatos
Membro desde: 07/12/18
415 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
Membros da 4
Autoria de 5 guias
2 comentários
I broke the screen on the same day I bought the phone. I have ordered a new one from ebay. I am going to try to install the screen with LCD digitizer.
Amresh Kadian - Responder
I had an amp 2 phone i accidently smashed it with my ps3 controller when I was playing games I smashed it on purpose so is this the way to fix the phone
darkwatch205 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 2,155
