Ir para o conteúdo principal
Samsung Galaxy Amp 2 Home Button Replacement
O que você precisa
  1. Samsung Galaxy Amp 2 Home Button Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Amp 2 Home Button Replacement, Battery: passo 1, imagem 2 %32
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. Samsung Galaxy Amp 2 Home Button Replacement: passo 2, imagem 1 %32 Samsung Galaxy Amp 2 Home Button Replacement: passo 2, imagem 2 %32 Samsung Galaxy Amp 2 Home Button Replacement: passo 2, imagem 3 %32
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
  3. Samsung Galaxy Amp 2 Home Button Replacement, Screen: passo 3, imagem 1 %32 Samsung Galaxy Amp 2 Home Button Replacement, Screen: passo 3, imagem 2 %32 Samsung Galaxy Amp 2 Home Button Replacement, Screen: passo 3, imagem 3 %32
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
  4. Samsung Galaxy Amp 2 Home Button Replacement: passo 4, imagem 1 %32
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
  5. Samsung Galaxy Amp 2 Home Button Replacement: passo 5, imagem 1 %32 Samsung Galaxy Amp 2 Home Button Replacement: passo 5, imagem 2 %32 Samsung Galaxy Amp 2 Home Button Replacement: passo 5, imagem 3 %32
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
  6. Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: passo 6, imagem 1 %32 Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: passo 6, imagem 2 %32 Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: passo 6, imagem 3 %32
    • Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
    • Push from the back panel to remove the bottom part of the motherboard.
    • Push from the front panel to remove the top part of the motherboard.
  7. Samsung Galaxy Amp 2 Home Button Replacement, Home Button: passo 7, imagem 1 %32 Samsung Galaxy Amp 2 Home Button Replacement, Home Button: passo 7, imagem 2 %32 Samsung Galaxy Amp 2 Home Button Replacement, Home Button: passo 7, imagem 3 %32
    • Pull the black tab that is located on the bottom of the motherboard.
    • Push the home button out of the black tab.
Conclusão
Uma outra pessoa concluiu este guia.
Cory Nickolatos
Membro desde: 07/12/18
415 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 464
